Will the diffuser cover of an LED ceiling light turn yellow over time?
Hi everyone,I’m looking at this LED ceiling light with a diffuser cover
Will the cover turn yellow after long-term use? I also want to know if PC or PMMA material is more durable than regular plastic, and how I should clean or maintain the cover.Any advice would be appreciated.
For LED ceiling lights, the diffuser cover plays an important role in light transmission, glare reduction, and overall lighting comfort.
Our ceiling light diffuser cover is made of anti-yellowing PC or PMMA material with UV protection treatment. Compared with ordinary plastic covers, this type of material is more resistant to discoloration and helps maintain better clarity after long-term use.
The diffuser is designed to provide soft and uniform light distribution, helping reduce harsh glare and making the ceiling light more comfortable for daily use in bedrooms, living rooms, hallways, kitchens, offices, and other indoor spaces.
Under normal indoor use, the cover can maintain good transparency and lighting performance for years. However, actual performance may also depend on the installation environment, operating temperature, ventilation, and cleaning method.
To help extend the service life and keep the diffuser looking clean, we recommend:
Avoid using strong acidic, alkaline, or corrosive cleaning agents.
Use a soft dry cloth or slightly damp cloth for cleaning.
Do not scratch the diffuser surface with hard tools.
Make sure the light is turned off before cleaning.
Avoid installing the fixture in environments with excessive heat, oil smoke, or chemical vapor unless the product is specifically designed for such conditions.
In general, anti-yellowing PC or PMMA diffuser covers are a reliable choice for LED ceiling lights, especially when you want long-term clarity, soft light, and stable appearance.
