Will smart lights still work if Wi-Fi goes down?
Hi everyone,
I’m thinking about installing smart downlights or floodlights, but I’m a little worried about the Wi-Fi connection.
If the Wi-Fi goes down, can the lights still be turned on and off normally? Or do they completely depend on the app?
Also, if the light supports Bluetooth, does that mean I can still control it without Wi-Fi?
Thanks in advance.
For smart lights, the control method depends on the specific model.
In general, Wi-Fi smart lights need a stable Wi-Fi connection for App control, remote control, and voice control through Alexa or Google Assistant. If the Wi-Fi is disconnected, these functions may not work normally until the network is restored.
However, the lights can usually still be turned on and off with a regular wall switch, just like normal lights.
For smart floodlights that support both Wi-Fi and Bluetooth, Bluetooth control may still be available when Wi-Fi is not connected, as long as your phone is within Bluetooth range and the product supports local Bluetooth control.
Before installation, we recommend checking the product description and pairing instructions to confirm whether the light supports Wi-Fi only or both Wi-Fi and Bluetooth.
