Will a Neon OPEN Sign Turn On Automatically After Power Is Restored?
For this neon open sign, if it is on and you unplug it… then plug it back in does it come on, or do you have to hit the on switch once it’s re-plug
Thanks for your question. Don’t need to press it again. It will stay lighting again as it was when you plugged it in earlier.
Is an LED neon OPEN sign suitable for glass storefronts?
Yes, it’s lightweight and low-heat.
Is it okay to keep an LED neon OPEN sign on for many hours every day?
Yes, that’s totally fine. I’ve been using mine for the whole business day (around 10–12 hours daily), and it’s been working normally with no issues so far.
If an LED neon OPEN sign is unplugged while on, will it turn on automatically when plugged back in?
