Which app controls this RGBCW smart ceiling light?
Hi everyone,
I’m looking at this product:
2 Pack 24W 12" Smart RGBCW Ceiling Light Fixtures
It supports RGB color changing, adjustable color temperature (2700K–6500K), dimming, and works with Alexa / Google Home.
I’d like to know which app is used to control these lights.
Is it a dedicated brand app, or a third-party app like Tuya or Smart Life?
Thanks in advance.
Does it support routines or automation schedules?
Does the light remember the last setting after being turned off?
Yes, the light usually remembers the last brightness, color, and color temperature when turned off using the app, remote, or voice control.
If you cut power with a wall switch, it will generally return to the last setting, though some units may briefly default to white after power is restored.
Does the remote control work independently from WiFi?
Hi,
Thanks for your question.
Just to confirm first — have you already purchased the 2-Pack 24W 12" Smart RGBCW Ceiling Light, or are you still considering it? This helps make sure the information fits your situation.
Regarding app control, these lights are controlled via the Tuya Smart app. After connecting to Wi-Fi, you can adjust brightness, RGB colors, color temperature (2700K–6500K), and set schedules directly in the app.
They also support Alexa and Google Home voice control, and each set includes a remote controller, so using the app is optional.
If you have any questions about setup or compatibility, feel free to ask.
