When dimming LED strips, is it the power supply or the controller doing the work?
I’ve been looking into LED strip dimming setups recently and noticed that power supplies, controllers, and dimming methods are often discussed interchangeably — which can get confusing.
My current understanding is:
  • The power supply converts AC to stable DC
  • The controller handles brightness, color, and effects
However, in real applications I keep seeing two very different approaches:
  • Low-voltage (DC-side) dimming using PWM dimmers or controllers
  • High-voltage (AC-side) dimming using wall dimmers with dimmable power supplies
So I’m curious about real-world experience:
  1. What’s the practical difference between these two dimming methods?
  2. Which approach is more common in residential vs commercial projects?
  3. Where does dimming actually happen — at the power supply or the controller?
  4. Has LED strip dimming evolved beyond simple brightness control into a full system?
Good questions — here are direct answers aligned with each point you raised.
1. Where does dimming actually happen — power supply or controller?
It depends on the system design.
In most LED strip setups, the controller or dimming signal performs the actual dimming, while the power supply provides stable DC output.
In AC-side dimming systems, the power supply translates the dimming signal into DC output changes.
2. What’s the real difference between DC-side and AC-side dimming?
  • DC-side dimming:
    Dimming occurs after DC conversion, typically via PWM
    Flexible, fast, and easy to expand
  • AC-side dimming:
    Dimming happens at the AC input, with the power supply adjusting DC output
    Closer to traditional wall-dimmer behavior
3. Which is more common in residential vs commercial projects?
  • Residential / DIY / smart lighting:
    DC-side dimming is more common
  • Commercial / architectural projects:
    AC-side dimming or centralized control is more typical
This is largely driven by installation and control preferences.
4. Is dimming now more than just brightness control?
Yes.
Modern systems often include:
  • Scene and schedule control
  • Motion-based automation
  • Smart home integration
  • Signal management for long runs
At this stage, LED strips behave more like systems than simple light sources.
