When planning architectural or decorative lighting, LED wall washers are often chosen for their ability to shape space and highlight surfaces.
From real-world projects, selection usually comes down to three key factors:
Brightness – determines how far the light reaches and how evenly the wall is washed
Beam angle – affects whether the light is focused for vertical accents or spread wide for ambient effects
Waterproof rating (IP) – defines where the fixture can be safely used, especially in outdoor or semi-outdoor areas
In theory, all three matter. But in practice, trade-offs are often unavoidable due to budget, installation limits, or fixture size.
Which factor do you usually prioritize first, and why?
Have you ever changed your decision after installation?
