What is the depth of this open LED neon sign?
Can anyone confirm the depth of this open LED neon sign? I need to know the front-to-back thickness for installation planning.
https://www.ledlightsworld.com/products/open-led-neon-sign-rectangular-4-glow-color-options-16-9-23-12-inch-window-hanging-plug-play-for-storefronts
The total depth (front-to-back thickness) of the sign is 1.5 cm (0.59 inch), including the acrylic backboard.
The acrylic backboard thickness itself is approximately 0.5 cm (0.2 inch).
Hope this helps with your installation planning. Please feel free to let us know if you need anything else.
0.59 inch is actually quite slim. I was expecting it to be thicker. That should make it easy to mount on glass or storefront windows.
Good to know the backboard is only 0.2 inch. That helps a lot if you’re planning to hang it with suction mounts or inside a window frame.
Yes, the slim profile is designed to make installation easier, especially for storefront windows and indoor displays where space is limited. The lightweight structure also helps with hanging installation and visibility.
