What does “5IN1 dimming” mean on an LED driver?
Hi , I saw an LED driver listed with “5IN1 dimming.” Does this mean it supports several dimming methods ? Can anyone explain what dimming types are included and whether it works with most dimmers?
“5IN1 dimming” means this LED driver supports five common dimming methods, including Triac, ELV/MLV, 0-10V, 1-10V, 10V PWM, and resistance dimming.
This design allows the driver to be compatible with different dimming systems, making it more flexible for various lighting installations.
Before use, we recommend checking which dimming method your existing dimmer or lighting control system supports, and then matching it with the correct wiring method on the driver.
