Things I wish I knew before installing under-cabinet lights (kitchen & closets)
Hi everyone,
I just finished installing under-cabinet lights in my kitchen and closets, and I wanted to share a few things I wish I’d known earlier. Hopefully this helps anyone planning a similar setup.
What worked well:
  • Surface-mounted lights were much easier since my cabinets were already installed
  • Mounting the lights closer to the front edge really reduced counter shadows
  • Motion-sensor lights are surprisingly useful in closets and drawers
  • Plug-in lights feel more stable for kitchens, while rechargeable ones work well where wires are hard to hide
Mistakes I made at first:
  • Light bars that were too short left dark gaps
  • Exposed cables ruined the clean look
  • Very cool white light felt harsh, especially at night
Overall I’m happy with the result, but it definitely took some trial and error.
Curious if others had the same experience — or if you’ve found better ways to handle light placement, wiring, or color temperature?
Great insights — thanks for sharing such a detailed real-world setup experience.
You touched on a few points many people overlook at first, especially front-edge placement and proper light length planning.
For anyone still planning their installation, we usually recommend:
  • Measuring the full cabinet run to avoid dark gaps
  • Choosing warmer or neutral white for living spaces used at night
  • Planning cable routing or wire channels before mounting
