I’ve been using other LED display models before, but this is my first time trying a NovaStar display, and I’m noticing a lot of small things that can go wrong.
For example, connecting the sending and receiving cards isn’t always smooth, and SmartLCT sometimes can’t detect the devices. If the module layout or screen size isn’t set correctly, the image can be misaligned or the colors can look off. Brightness and color adjustments are also tricky—if not done right, the screen looks uneven.
Has anyone dealt with these issues in real cases and can share some examples to help me figure it out?
Thank you for sharing your experience. These kinds of issues are actually quite common when first working with NovaStar.
Based on a summary of problems encountered by multiple users during real-world installations, it’s generally recommended to start by checking the hardware connections one by one—make sure the sending card, receiving card, and network cables are all properly connected before opening the SmartLCT software. If the software cannot detect the devices, in many cases it’s not an issue with the cards themselves, but rather the signal sequence or connection method being incorrect.
If you encounter image misalignment or color inconsistencies, focus on verifying the cabinet size, module resolution, and data flow settings. Even small parameter mismatches in SmartLCT can cause image flipping or local color deviations.
Regarding brightness and color, it’s recommended to perform a basic brightness uniformity and color calibration once the screen mapping is complete. Many users overlook this step in the early stages, which can affect the overall display quality.
Following this order of checks and settings usually helps the system stabilize faster and avoids most issues that new users typically face.
—LEDLightsWorld Team
