Struggling with Silicone LED Tubes – Tips for Choosing the Right Housing?
Hey everyone, I’ve been installing silicone LED tubes on a few projects over the past couple of years, and I’ve noticed that a lot of the small issues later on usually start with the tube itself.
For example, I used a flexible tube on a curved corner once. It barely fit during installation, and after a while, the corners started looking uneven and the strip shifted inside. Switching to a tube made for side bending fixed it right away.
On straight runs, I tried a round tube, but it didn’t hold well over time — a bit of sagging made the light line look messy. Switching to a square-profile tube with clips or channels kept everything straight and stable.
Maintenance was another headache. Fully sealed tubes are a pain to open, but ones with removable ends made replacing strips so much easier.
Has anyone else run into these issues? How do you usually pick silicone tubes so they stay straight, bright, and easy to maintain?
Thanks for sharing your real-world experience — you’ve actually pointed out several of the most common issues we see from customers after installation.
From a manufacturer’s perspective, most long-term problems with silicone LED tubes do come down to profile selection and intended bending direction:
  • Bending type matters a lot. Using a top-bend tube on a side-bend application (or forcing a tube beyond its designed radius) often leads to internal shifting over time, exactly like you described. For curves and corners, choosing a tube specifically designed for side bending with a defined minimum bend radius is critical.
  • Profile shape affects stability. Round tubes look clean, but on long straight runs they’re more prone to sagging if not fully supported. Square or flat-top profiles, especially when paired with mounting clips or aluminum channels, provide much better long-term straightness and visual consistency.
  • Maintenance-friendly design is often overlooked. Fully sealed, glue-filled tubes are great for harsh environments, but for indoor or semi-protected applications, tubes with removable end caps or serviceable designs make future LED strip replacement far easier and more cost-effective.
When we help customers choose silicone tubes, we usually suggest starting with three questions:
  1. Is the run straight or curved (and in which bending direction)?
  2. Will it be surface-mounted, recessed, or clipped into a channel?
  3. Does the project require future access for maintenance or upgrades?
Answering these upfront avoids most of the issues you mentioned and keeps the lighting looking clean and consistent over time.
Appreciate you bringing this up — threads like this are really helpful for people planning their first silicone tube install.
This topic was automatically closed after 166 days. New replies are no longer allowed.
