Looking for a 12V 2.5A 30W power supply
I’m looking for a power supply that has: Input ac100-265V, 50/60 hz. Output DC 12V, 2.5A, 30W.I only need 2 units for now.
Does anyone have a recommendation?
A suitable option would be a 12V waterproof LED power supply with the following specifications:
Input: AC90-265V, 50/60Hz
Output: DC12V, 2.5A
Power: 30W
Protection Rating: IP67
Product link:
This model matches the voltage and current requirements you listed and is suitable for both indoor and outdoor LED applications.
We can supply the 2 units you need.
If you’re planning to expand your setup later, it may be worth considering a slightly larger power supply. Running a power supply continuously at its maximum rating isn’t always ideal.
That’s a good point. For LED installations, many customers prefer leaving some extra capacity for future expansion and long-term reliability. However, if the total load is around 30W or below, this 12V 2.5A model is an appropriate match.
I’ve used similar 12V 30W IP67 drivers for outdoor LED strips and landscape lighting. The waterproof housing is nice to have even when the installation is partially sheltered.
