I recently installed an LED strip, but it does not turn on at all after wiring. Here’s what I’ve checked so far:
Using a 12V LED strip
Powered by a 12V constant voltage power supply
Power supply indicator is on
Output voltage measures correctly
No visible damage on the LED strip
Installation details:
Strip length: approx. 5 meters
No parallel power injection
Standard on/off switch (no dimmer)
No controller, strip connected directly to the power supply
1.What are the most common failure points in this situation?
2.Could reversed polarity or soldering issues cause this?
3.If the strip was briefly connected to the wrong voltage, could it look normal but stop working?
4.Is there a recommended step-by-step troubleshooting order?
Based on similar installations we’ve handled, this type of issue is actually quite common. When a 12V strip shows no response at all even though the power supply tests correctly, the most frequent causes are polarity errors, connection quality, or internal strip damage.
First, reversed polarity is very easy to overlook. Many LED strips won’t light at all if + and – are swapped, but they also won’t show any visible damage. It’s worth double-checking polarity directly at the strip pads, not just at the power supply terminals.
Second, solder joints and connectors are a major failure point. Cold solder joints, broken copper pads at the cut point, or loose DC connectors can all result in a “dead” strip even though voltage is present upstream. Testing a short section of the strip directly at the power supply can quickly rule this out.
Regarding wrong voltage exposure: yes, even a brief connection to a higher voltage (for example 24V on a 12V strip) can permanently damage the internal resistors or LEDs. In that case, the strip may look completely normal but will no longer light.
A practical troubleshooting order that usually works is:
1.Confirm polarity at the strip input
2.Test the strip with a very short direct connection (no switches or extensions)
3.Inspect or re-solder the first connection point or cut pad
4.Test a different section of the strip if possible
In many cases, the issue turns out to be at the first connection point or the strip was already damaged before final installation.
