LED screen looks dim and uneven – calibration issue or receiving card settings?
After installing an indoor LED display, we noticed:
Overall brightness is low
Some areas are darker than others
White looks gray, not clean
Sending and receiving cards are detected normally
Power output and network cables have been checked and seem fine.
  1. Is this more likely a calibration issue or a receiving card parameter problem?
  2. Do we need to redo brightness and color calibration?
  3. Should troubleshooting start from software settings or hardware first?
This is usually a configuration or calibration issue rather than a hardware fault.
Recommended steps:
  1. Check brightness limits on receiving cards
    Make sure brightness is not limited to 50% or lower.
  2. Verify calibration files
    Without proper calibration, uneven brightness and color shift are common.
  3. Unify brightness and contrast settings
    Ensure software and sending card settings match.
  4. Check hardware last
    Only inspect power and cables after confirming all parameters are correct.
Start with software settings and calibration before suspecting hardware problems.
