Hi everyone, I’m thinking about getting the LED Open Sign for my shop. I’m not very handy with tools—does it come with everything I need to hang it up, or will I need extra equipment?
https://www.ledlightsworld.com/products/open-led-neon-sign-rectangular-4-glow-color-options-16-9-23-12-inch-window-hanging-plug-play-for-storefronts?variant=46707675136248
Thank you for your question. Yes, the LED Open Sign is very easy to install. It comes with a hanging chain and all the mounting hardware you need, so no extra tools are required. Simply hang it and plug it in!
Can this LED Open Sign be used outdoors, or is it strictly for indoor use?
The OPEN LED Neon Sign is for indoor use only and is not waterproof. Please keep it away from rain or high humidity, or use proper weather protection if placed outdoors.
Is there a switch to turn the sign on and off, or do I have to unplug it every time?
It includes a control switch on the adapter, so you can turn it on or off without unplugging. Power is supplied via a 12V adapter with a US plug (or UK version, depending on the model).
