LED Bulbs – Why Do Some Look Different?
I recently installed a batch of LED bulbs at home. Wiring and fixtures were fine, but once I turned them on, some bulbs looked dimmer than others, and a few didn’t match in color.
At first, I thought I messed up the installation or maybe it was the transformer. After checking everything, it turned out the bulbs themselves were the issue—some weren’t converting power efficiently, and color varied between batches.
I switched to a better-quality set, didn’t touch anything else, and everything matched perfectly.
Has anyone else run into this? How do you usually pick LED bulbs to avoid mismatched brightness or color?
Hi, thank you for sharing your experience!
What you described is actually a common situation with LED bulbs. Even when wiring and fixtures are correct, differences in bulb quality or between production batches can lead to variations in brightness and color.
To help avoid this, we usually recommend:
  • Choose bulbs from trusted brands or suppliers with stable quality control.
  • Check luminous flux and color temperature specifications to ensure consistency.
  • Use bulbs from the same production batch whenever possible.
We’re glad to hear that switching to a higher-quality set solved the issue without changing any wiring or fixtures. Selecting reliable bulbs is often the simplest way to ensure uniform lighting throughout your space.
If you have any further questions about bulb selection or installation, feel free to reach out—we’re happy to help!
This topic was automatically closed after 167 days. New replies are no longer allowed.
