I’m looking for an industrial switching power supply for an LED project and found this metal case model:
My main concern is long-term reliability. What safety protections should this type of power supply have, and what should I pay attention to when running it continuously with LED lights or other devices?
This switching power supply main protection functions include:
Short-circuit protection: Helps protect the power supply and connected devices in case of an output short circuit.
Overload protection: Activates protection when the load exceeds the rated capacity.
Over-voltage protection: Helps prevent abnormal output voltage from affecting connected equipment.
Over-current protection: Limits excessive current to protect the power supply and load.
Overheat protection: Provides protection when the internal temperature becomes too high.
Leakage protection: Improves safety during operation.
For continuous applications such as LED strips, LED display systems, or other electronic devices, we recommend selecting the correct power rating based on the actual load and leaving some power margin instead of operating the power supply at full capacity for extended periods. Proper ventilation should also be maintained, and installation in high-temperature, enclosed, or damp environments should be avoided.
During installation, please ensure all input and output wiring is connected correctly. For permanent installations, professional installation according to local electrical requirements is recommended to ensure safe and reliable long-term operation.
