I’m planning to install LED strip lighting under my bathroom cabinets for toe-kick accent lighting.
The installation length will be around 48–52 inches. I prefer a 24V RGBW strip so I can have both color effects and a dedicated white light option.
I already have a 0–10V dimmer installed. What additional components do I need to make this setup work properly?
Thank you for providing the details.
For your bathroom toe-kick lighting project, a 24V RGBW LED strip would be a suitable option. This type of strip can provide both RGB color effects and dedicated white light output for different lighting needs.
Since you already have a 0–10V dimmer installed, we recommend confirming your existing control system before selecting the final configuration. RGBW systems typically require a compatible controller in addition to the LED driver and strip.
Could you please share the brand and model number of your current 0–10V dimmer, or provide a photo of the product label?
Once we confirm your existing setup, we can recommend the appropriate driver and controller combination to ensure the RGBW system works properly.
