I’m planning a semi-outdoor linear lighting project, with LED strips installed under building eaves and recessed grooves. I’m currently deciding between IP65 and IP67 LED strips and would appreciate real-world insights.
Project background:
Environment: Outdoor but under eaves, not directly exposed to heavy rain
Installation: Recessed aluminum profiles
Long strip runs with segmented power supply
Preference for easier long-term maintenance
Key questions:
Is IP65 sufficient for this type of semi-outdoor environment?
Does IP67 significantly increase heat dissipation or maintenance difficulty?
From a long-term reliability perspective, which option performs better?
Are there any balanced recommendations or critical details to watch out for?
Looking forward to practical project experience rather than datasheet explanations. Thanks!
