From actual installations, maintenance seems to matter more than people expect. Based on real use cases, the biggest factors affecting ticker lifespan and stability are usually:
Dust & cleaning — Dust buildup slowly reduces brightness and causes uneven display.
Temperature & humidity — Heat and moisture shorten LED life and damage internal electronics.
Power quality — Poor cabling, unstable voltage, or lack of surge protection often trigger failures.
Software & network — Outdated firmware or unstable CMS leads to lag, freeze, or data not updating.
Installation stability — Loose brackets or poor ventilation eventually create bigger issues.
These issues are “invisible” at the beginning, but in long-term use they determine stability, readability, and lifespan.
Curious to hear your experience:
Which one has caused you the most trouble in real projects — cleaning, heat, power, software, or installation?
Or did you face something else entirely?
