I’m considering the FL-DMX Series RGB LED Flood Light (100W or 150W) for an outdoor project.
Just wondering — can these lights create dynamic effects like wave movement and color changing through DMX, or are they simply basic on/off flood lights?
Thank you for your inquiry about the FL-DMX Series RGB LED Flood Light.
This model works with a DMX control system. All dynamic lighting effects, including color changing, wave movement, chasing, and other programmed scenes, are controlled through an external DMX controller.
So it is not just a simple on/off flood light. With a compatible DMX controller, you can create various customized lighting effects to meet your project needs.
If you have any other questions or need technical assistance, feel free to let us know.
The housing is made of aluminum with a tempered glass cover.
This structure provides good heat dissipation and durability, making it suitable for long-term outdoor use.
This series supports a wide input voltage range of AC85–265V.
It can be connected directly to standard 110V or 220–240V AC power without an additional transformer.
