I’m installing LED strips and noticed very mixed opinions about aluminum channels.
Some say any profile works, others say it affects dot visibility and overall finish.
So I’m wondering: in real use, does the aluminum channel really make a noticeable difference to the lighting result?
Based on feedback from real installations, aluminum channels do make a difference — but how noticeable it is depends on the application.
When LED strips are directly visible (such as under cabinets or exposed linear lighting), the channel can clearly affect dot visibility and overall light uniformity.
When strips are hidden or used for indirect lighting, the impact is usually much less noticeable.
Most concerns about aluminum channels are less about whether the light works, and more about how “finished” the final result looks.
So whether it’s worth paying close attention mainly depends on visibility and visual expectations.
