Is there a datasheet for the 850nm SMD5050 DC12V Infrared LEDs?
https://www.ledlightsworld.com/products/850nm-smd5050-dc12v-infrared-led-strip-light-high-brightness-ir-for-security-30-60-120-leds-m-5-meters-ip00-ip65?srsltid=AfmBOopRPPYLIr2S7c-tR8ke-3T3wAs4QI4jOilGZA6NCHDeCuCIqPph
Thank you for your message.
I have attached the datasheet image for our 850nm SMD5050 DC12V Infrared LED Strip, covering all three versions: 30 LEDs/m, 60 LEDs/m, and 120 LEDs/m (dual row).
Please refer to the table in the image for detailed specifications including wavelength, LED type, voltage, wattage, beam angle, cuttable section, strip dimensions, PCB color, protection grade, and dimmable information.
