I’ve been messing around with a few LED strip projects using silicone sleeves and definitely ran into some issues. Just sharing a few things I learned the hard way — might help others.
Dust or moisture inside the sleeve
Almost always bad end sealing, not the strip itself. For outdoor or humid setups, sealing the ends is critical. -
Heat & power
I used to run strips at full power all the time. Turns out that shortens lifespan fast. Aluminum channels and some power headroom helped a lot. -
Only part of the strip lights up
Usually happens at cut points or where the strip bends too sharply. Way more common than I expected. -
Whole strip dead?
Before replacing it, I now double-check voltage, polarity, and fuses. Often it’s just wiring.
For silicone sleeve size, I don’t focus on looks anymore. Narrow sleeves for fine lines, wider ones for more even light on bigger designs.
Just curious:
What do you usually figure out first — power, sleeve size, or heat management?
