Choosing between P2.5 and P3 LED displays for retail window installations?
I’m currently planning an LED display setup for a retail storefront window and would really appreciate some real-world decision-making experience.
Project background:
  • Application: retail glass storefront
  • Viewing distance: approximately 2–5 meters
  • Content: branding, promotions, dynamic visuals
  • Mounting preference: window-mounted or suspended, minimal structural work
  • Operation: both daytime and nighttime use
I’m currently deciding between P2.5 and P3, and have a few questions:
  1. At a 2–5 m viewing distance, is the visual improvement of P2.5 over P3 noticeable in practice?
  2. For window displays, is smaller pixel pitch truly necessary?
  3. How significant are the differences in cost, power consumption, and maintenance?
  4. From a long-term reliability standpoint, which option is the safer choice?
If you’ve worked on similar retail or window display projects, I’d love to hear your experience.
Looking for practical insights and decision logic, not just spec comparisons. Thanks!
Thanks for contributing to LEDLightsWorld Community!
We’ve used both P2.5 and P3 in retail window display projects over the past few years. Here’s how we typically approach the decision in practice.
Viewing distance & visual impact
At a 2–5 m viewing distance, P2.5 does offer finer detail — especially for text, small icons, and high-contrast content. However, for promotional videos, motion graphics, or large typography, P3 does not feel visually coarse in real-world use.
Is smaller pixel pitch necessary?
For storefront windows, choosing P2.5 mainly makes sense if:
  • The content includes fine details or small text
  • Viewers are expected to stand very close to the glass
If the display focuses more on branding visuals and atmosphere, P3 is usually sufficient.
Cost & maintenance
P2.5 comes with higher initial cost, higher pixel density, and slightly higher power consumption. It also requires more precise installation and system configuration.
P3 tends to be more forgiving, easier to maintain, and often more stable for long-term operation.
Our recommendation
  • Sidewalk-facing storefronts with branding-focused content → P3 offers better value
  • Displays intended for close-up viewing and information-heavy content → P2.5 is worth considering
In short, both work well for retail windows. The real deciding factor is not the spec sheet, but content strategy and viewer behavior.
