Has anyone connected two 50M high voltage LED neon strips to the same power source before? I’m planning a long outdoor install and trying to figure out if running 100M together will cause any brightness or overheating issues, or if it’s better to power them separately.
For the High Voltage Single Color LED Neon Rope Light - 8x16mm | SMD2835 120LEDs/m | AC110V / 220V Flexible Neon LED Strip, each power plug is designed to support a maximum continuous length of 50 meters only.
Therefore, two 50-meter rolls cannot be connected together and operated from a single power source.
If you require a total length of 100 meters, it is necessary to use two separate 50-meter rolls, with each roll connected to its own dedicated power plug.
We hope this information is helpful. Please feel free to contact us if you have any further questions.
