Can these lights stay on 24/7, or do they need to be turned off regularly?
Yes, these lights are designed for long-term continuous operation and can remain on 24/7 under normal installation and usage conditions.
Based on feedback from many users, they have been widely used in applications such as boats, RVs, landscape lighting, and decorative projects that require extended periods of illumination. Users have reported reliable performance even after long-term use.
Please note that environmental factors such as temperature, humidity, or mounting surface conditions may affect the adhesive over time. If the strips become loose, they can simply be re-secured without affecting the performance of the lights themselves.
Overall, when installed properly, these lights are well-suited for continuous, around-the-clock operation.
My experience has been pretty similar. I’ve had these installed under my patio for almost a year and a half, and they’re often left on for days at a time. So far, I haven’t noticed any dimming or failures.
The only minor issue I’ve had is the adhesive loosening in a few spots during hot weather, but it was easy to secure again. The lights themselves have continued to perform reliably.
Overall, they’ve been more durable than I expected.
