Can these Downlights be used outdoors?
Can it be used outdoors?
2 Inch LED Recessed Lighting, 3W Dimmable Downlight, 5000K Daylight White, White Retrofit Recessed Lights with Driver, 4Pack
No, the Bingotec 2 Inch LED Recessed Lighting is designed for indoor use only and is not suitable for outdoor installation.
The product specifications clearly indicate ““Indoor/Outdoor Usage: Indoor”” and ““Water Resistance Level: Not Water Resistant.”” It’s specifically designed for indoor spaces like bedrooms, kitchens, living rooms, hallways, offices, basements, and similar indoor environments.
The recessed led fittings, simple or complicated installation?
It is easy to install, first cut hole in the ceiling(Fits 2.16 ~ 2.4inch hole), then connect wires & fixed via spring clips. LED dimming driver is included. No additional accessories are required. The user manual is included in the package.
How many 2inch lights do I need for a 11ft by 8ft living room with 8 foot ceiling?
I put mine every 5.6 feet, they provide plenty of light
Is the recessed light dimmable?
Yep, it’s dimmable.
Dimmable LED recessed lights will help us control the light and set the mood. As LED recessed lights are fixed in the ceiling and often provide general lighting, it is a good idea to make sure the lights are dimmable, so we can adjust the level of brightness to suit our activities, for example in a living room, bedroom, kitchen etc.
