Can the 395nm-405nm SMD2835 UV LED strip be cut and reused?
I’m looking at the 395nm-405nm SMD2835 UV LED strip and was wondering if it can be cut in half and still be used. If I cut the strip, can both halves work independently?
That’s correct.
The LED strip can be cut at the marked cutting sections, and each segment can continue to operate as long as power is connected properly to the positive and negative terminals.
For permanent installations, soldered connections are generally recommended. Some customers also use compatible strip-to-wire connector clips for quicker installation without soldering.
I’ve done this with UV strips before. Soldering is probably the most reliable option, but there are also solderless connector clips available that can attach directly to the strip.
They make installation easier if you don’t want to solder, although I don’t remember the exact brand I used.
Yes, these strips can be cut at the designated cut points.After cutting, you can solder small wires to the copper terminals on each section so both halves can be powered separately.
If you’re using the waterproof version, you’ll need to carefully remove a small section of the silicone coating to access the solder pads.
