Can I Mount 3 Hologram Fans Together?
I’m thinking about getting three hologram fans and would like to combine them to create a larger display.
Can three hologram fans be mounted together like this? Do I need a special frame or stand to keep them properly aligned?
Product:Custom Multi-Fan Stand Mount | 3D Hologram Fan LED Display | LED Hologram Projector | 1×3 / 2×3 / 3×3 Fan Array Configurations | Compatible with 3D Hologram Fans ≤100cm | Modular Steel Frame
Yes, multiple compatible hologram fans can be mounted together using a multi-fan mounting frame.
The product you referenced is a multi-fan stand/mount, designed to securely position multiple compatible hologram fans together in configurations such as 1×3, 2×3, or 3×3.
For three fans, the appropriate configuration can be selected based on your preferred display layout. Before ordering, please confirm the size and model of your hologram fans so we can verify that they are compatible with the mounting frame.
