Can a 3D hologram fan project a floating image upward from a tabletop?
Hi everyone,I’m planning to use a 3D hologram fan for a tabletop presentation.I would like to place the device on a table and display a floating 3D image above it. Does this type of hologram fan project the image upward into the air, or does it need to be viewed from a specific angle?Any advice would be appreciated.
Our 3D hologram fan creates visual effects through high-speed rotating LED blades that display images and videos on the blades.
When viewed from the front, the displayed content creates a vivid 3D holographic effect, making the images appear as if they are floating.
Please note that the hologram fan does not project a physical 3D image upward into the air or create a separate free-floating hologram above the device. The 3D effect is generated by the LED blades themselves, and the best viewing experience is from the front of the display.
For tabletop presentations, the device should be installed in the correct upright position to ensure safe operation and the best display performance.
I think it’s more like a floating visual display created by the LED blades rather than a real 3D object in the air. Once you understand how it works, the effect is pretty impressive.
