Can a 0–10V Dimmer Control an RGBW LED Strip?
I’m installing a new toe-kick lighting system with a 24V RGBW LED strip.
I already have a Leviton ODD10-IDW 0–10V wall dimmer and I’m trying to figure out what else I need. Will this dimmer work with an RGBW controller, or do I need a different driver or controller for the installation?
Any advice would be appreciated.
For a new RGBW LED strip installation, you’ll typically need a 24V LED power supply (driver) and an RGBW controller in addition to the LED strip itself.
The Leviton ODD10-IDW is a 0–10V wall dimmer. While it is designed for 0–10V dimming systems, standard RGBW controllers do not typically accept a direct 0–10V input signal. As a result, they cannot be connected directly to this dimmer.
If you would like to keep the Leviton wall dimmer as your primary control device, a compatible 0–10V to RGBW control interface would be required. Alternatively, you can use a dedicated RGBW controller that provides independent control of brightness, white light, and RGB color functions.
If you’re unsure which configuration is best for your project, feel free to share your installation requirements, and our team will be happy to help recommend a suitable solution.
