Has anyone used a 3D hologram fan at trade shows or exhibitions?I’m looking for something around 40cm in diameter that can sit on a table or display counter. Ideally, it should be compact enough to transport between events.
I’m also wondering about safety. Since these fans have spinning blades, would a protective cover be necessary for an exhibition booth where visitors might get close?
For trade shows, I’d definitely go with a protective cover, especially if it’s sitting on a table where people can walk right up to it.
A desktop stand would also make more sense than a wall-mounted setup if you’re moving between different events.
For this type of setup, we’d recommend our F45Plus 42cm (16.5") Desktop 3D Hologram Fan.
You can check the complete setup here:
The set includes a 42cm hologram fan, a full transparent square protective cover, a black desktop base, and a power adapter.
The 42cm display is close to your preferred size, and the protective cover helps prevent accidental contact with the rotating blades while keeping the holographic effect visible.
It’s a suitable option for trade show booths and exhibition counters, especially if you need a tabletop setup that can be moved between events.
