24V LED strip flickering after installation - driver capacity is sufficient, what could be the cause?
I recently installed 24V LED strips in an indoor linear lighting project and ran into a flickering issue.
Project details:
LED strip type: 24V single-color LED strip
Installation: Recessed aluminum profile
Power supply: 24V constant-voltage driver with ~30% power margin
Dimming method: 0–10V
Issue description:
Slight flickering after power-on
Flickering becomes more noticeable at low dimming levels
Some sections are stable, others flicker
Troubleshooting already attempted:
Replaced the driver
Checked polarity connections
Tested each strip section independently
The issue persists. When driver power seems sufficient, what should be checked first in this type of flickering issue?
Could it be related to dimming compatibility or cable length? Thanks!
In cases like this, flickering is often not caused by insufficient power alone. Here’s a practical troubleshooting sequence.
Step 1: Verify dimmer–driver compatibility
0–10V dimming can be sensitive at low brightness levels:
  • Check if the dimmer output signal is stable
  • Confirm the driver officially supports the dimmer model
Unstable dimming signals are a common cause of low-level flicker.
Step 2: Check cable length and voltage drop
Even in 24V systems:
  • Long single power runs
  • Excessive series connections
Can cause voltage instability at the strip ends.
Use multi-point or segmented power injection where possible.
Step 3: Confirm minimum load requirements
Some constant-voltage drivers:
  • Become unstable under very low load or dim levels
  • Produce visible flicker
Testing with added load or a higher-quality driver can help identify this issue.
Step 4: Inspect heat dissipation
Poor thermal contact between the strip and aluminum profile can lead to:
  • Local overheating
  • Current fluctuation
Which may cause flickering.
Summary
When flickering occurs despite sufficient power,
dimming compatibility and power distribution are usually the key factors — not wattage alone.
