I recently installed a 12V LED strip, but it does not turn on at all after wiring. Here’s what I’ve checked so far:
Using a 12V LED strip
Powered by a 12V constant voltage power supply
Power supply indicator is on
Output voltage measures correctly
No visible damage on the LED strip
Installation details:
Strip length: approx. 5 meters
Single-side power input
Standard on/off switch (no dimmer)
No controller, strip connected directly to the power supply
1.What are the most common failure points in this situation?
2.Could reversed polarity cause the strip to stay completely off?
3.If the strip was briefly connected to the wrong voltage, could it appear intact but stop working?
4.Is there a recommended step-by-step troubleshooting order?
In cases where the power supply works normally but the LED strip stays completely off, the issue is usually related to polarity, connection points, or internal strip damage.
Reversed polarity is very common. Most LED strips will not light up at all if + and – are swapped, and there may be no visible signs of damage. It’s best to confirm polarity directly at the strip input pads.
The first connection point is another frequent failure area. Cold solder joints, damaged copper pads at cut points, or loose connectors can prevent the strip from lighting even when voltage is present. Testing a short section of the strip directly from the power supply helps isolate this.
If the strip was briefly connected to a higher voltage, internal components may already be damaged. In that case, the strip can look normal but will no longer function.
A practical order is to check polarity first, then test the strip directly, inspect connection points, and finally assess whether the strip itself is damaged.
