Manual request for Single Color LED Strip Mini Dimmer – DC12V-24V 12A | Push-Button Inline LED Dimmer Controller | For LED Strips
I want to check if this product meets my application. Here’s the link:https://www.ledlightsworld.com/products/mini-led-amplifier-controller-for-single-color-5050-2835-led-flexible-strip-light-max-144w-signal-amplifier?variant=46794012786936
To confirm whether this Single Color LED Strip Mini Dimmer (DC 12V–24V, 12A) is suitable for your setup, please share some details about your application. Specifically, we need to know:
The type of LED strip you plan to use
The operating voltage (12V or 24V)
Total load (watts or meters of LED strip)
Once we have this information, we can provide specific advice and ensure compatibility.
Does anyone know if it supports push-button short presses for on/off, or only dimming?
Just my 2 cents — I used it on a 12V LED strip and dimming is smooth.
I’m planning to use this dimmer for a 12V single-color LED strip in my living room. The total length is about 5 meters, around 72W. Will this dimmer work for my setup?
Can I use the same dimmer if I decide to extend the LED strip to 10 meters (144W) in the future?
Thank you for sharing your experience! Glad to hear it works smoothly with your 12V setup. This kind of feedback really helps others who are considering the same configuration.
Thank you for your question! The Mini Dimmer primarily focuses on dimming functionality. Short presses may work for on/off depending on the LED strip setup, but results can vary. We recommend checking the specific LED strip and wiring configuration to be sure.
Based on the details you provided (12V, 72W), this Single Color LED Strip Mini Dimmer (DC12V–24V, 12A) is compatible with your setup. It can safely handle up to 144W at 12V. Please ensure proper wiring and follow the installation instructions for safety.
Yes, the dimmer supports up to 12A, which equals 144W at 12V. Extending the strip to 10 meters is at the limit of the dimmer, so make sure the total load does not exceed 144W and that the wiring is properly rated. For longer runs, consider using multiple dimmers or a suitable power amplifier to ensure stable performance.
