I’m putting together a few small low-voltage devices, including a 6V LED strip, a small fan, and some DIY test boards. I’m looking for one 6V power adapter that can handle them.
I found this 6V desktop power supply with both 30W and 60W options:
https://www.ledlightsworld.com/products/dc-6v-desktop-power-supply-adapter-30w-60w-ac-100-240v-input-us-plug-switching-transformer-for-electronics-router-toys-diy-projects
What kind of devices can this type of 6V adapter usually power? How should I choose between 30W and 60W? Also, is it okay to run it close to full load for a long time?
Thanks for your interest.
This is a DC 6V desktop power adapter, available in two versions: 6V 5A 30W and 6V 10A 60W. It supports AC 100-240V input and provides stable DC 6V output. The connector is a 5.5 × 2.1mm DC male barrel plug, and it also includes a DC female screw terminal adapter. The product page lists both 30W and 60W output options, with 5A for the 30W version and 10A for the 60W version.
It is suitable for devices that require DC 6V input, such as 6V LED strips, CCTV cameras, routers, hubs, audio/video devices, small fans, small pumps, and DIY electronics projects. Before connecting it, the most important thing is to confirm that your device is designed for DC 6V input. It should not be used directly with 5V, 9V, 12V, or 24V devices.
For a short 6V LED strip, a single small device, or basic DIY testing, the 30W version is usually enough. If you plan to power a longer 6V LED strip or several devices at the same time, the 60W version would be the safer choice.
For continuous use, we do not recommend running the adapter at full load all the time. For the 30W version, it is better to keep the actual load around 24W or below. For the 60W version, keeping the load around 48W or below is a better choice. This helps reduce heat and improves long-term stability. The product page also recommends leaving 10%-20% headroom for continuous use to help prevent overheating.
In simple terms, choose 30W if your total load is under about 24W. Choose 60W if your total load is between about 24W and 48W. If your load is higher than 48W, this adapter is not ideal for long-term use, and a higher-power 6V power supply would be recommended.
