Project Planning Stage: How to Choose the Right LED Display Solution for Multiple Application Scenarios?
I’m currently planning an LED display project and still in the stage of clarifying requirements and comparing solutions. The project can be summarized as follows:
  • Application scenarios include:
    • Indoor commercial displays
    • Semi-outdoor storefront or entrance-facing areas
  • Viewing distance is approximately 2–8 meters, depending on the area
  • Display content mainly includes brand videos, promotional information, and dynamic text
  • The overall solution should be flexible, allowing size or layout adjustments in the future
I’d love to hear from people with real-world planning or implementation experience:
  1. In a single project with both close and mid-range viewing distances,
    is it more practical to use one unified pixel pitch or configure different pitches by area?
  2. When it comes to size planning, is it better to finalize the dimensions early,
    or prioritize a modular, expandable design?
  3. For areas near storefronts or exposed to ambient daylight,
    does brightness need to be noticeably higher than standard indoor displays? Are there any practical benchmarks?
  4. Do non-traditional display forms such as hologram fans or cube displays
    work better as primary visual elements, or as supplementary displays?
  5. During the solution design stage, which factors are most often overlooked,
    such as splicing methods, maintenance access, control system compatibility, or upgrade costs?
I’m hoping to understand how others approach decision-making during the project planning stage,
which choices later proved to be critical,
and what considerations are worth addressing early on.
Any experience or insights from similar projects would be greatly appreciated.
Here are some practical tips based on similar LED display projects:
  1. Pixel pitch: Use smaller pitch for close-view zones and slightly larger pitch for mid-range areas to balance clarity and cost.
  2. Size planning: Modular, expandable design is usually better than locking in dimensions too early.
  3. Brightness: Semi-outdoor or daylight-exposed areas need higher brightness (around 2500–4000 nits) than standard indoor displays.
  4. Non-traditional displays: Hologram fans or cube displays work best as supplementary elements, not the main display.
  5. Other considerations: Panel alignment, maintenance access, control system compatibility, and future upgrades are often overlooked but critical.
Early planning around these points typically saves time and ensures better results.
