I’m looking for an LED aluminum channel to replace my existing profile.Width: 13/16 inch,Height: 3/8 inch;
I attached a photo of my current channel. Does anyone know a suitable replacement?
Thank you for providing the dimensions and photo.
Based on your requirements, you may take a look at our U03-A LED aluminum channel:
Product link:
The profile dimensions are approximately:
Internal width: 20.6 mm (0.81")
Height: 10.84 mm (0.43")
It is suitable for LED strips up to 20 mm wide.
Please compare the cross-section dimensions with your existing profile to confirm whether it will fit your application.
Checking the internal dimensions is really important. The outside size of aluminum profiles can look similar, but the actual LED strip space can be very different.
Yes, especially when replacing an existing channel. The diffuser and mounting method also need to match, not just the width.
