I recently finished installing LED strips (mostly under cabinets and in a few tight spaces), and I honestly didn’t expect connectors to be the part that caused the most trouble.
Most of the issues I ran into — half-lit strips, flickering, or sections not turning on at all — came down to mismatched connectors, not the strips themselves.
A few things I learned the hard way:
Strip width really matters (8mm / 10mm / 12mm) — even slightly off = loose contact
Pin count has to match exactly (2-pin single color, 3-pin CCT, 4/5/6-pin RGB types)
COB strips need low-profile connectors, especially inside aluminum channels
Bulky connectors can prevent diffusers/covers from closing
Test-fit everything before final install — saved me from tearing things apart later
I also underestimated how useful extension cables and waterproof connectors are, especially for longer runs or outdoor setups.
Did anyone else struggle more with connectors than expected?
How do you usually deal with corners, tight channels, or hidden transitions?
