My first proper LED project for a cabinet I’m building. Looking for some advice and what is probably a very simple system, but I can’t decide if it’ll work.
My planned set up is:
mains—> LED driver (150w) non-dimmable —> door sensor (rated to 120w on 24v) —> manual rotary dimmer —> LED tape (total 80w)
Will this work?
My logic is that the sensor needs constant 24v to work, so I should put the dimmer after this and I need a dimmer to remember the settings so it doesn’t just go back to 100% every time. I tried AI but it just keeps agreeing with me about everything, so not sure if I’m being gaslit?
Your setup looks reasonable in principle, assuming everything is rated for 24V DC.
The 150W power supply and 120W door sensor should be sufficient for your 80W load. Just make sure the sensor is compatible with the dimmer, including its startup current.
For brightness memory, a traditional rotary PWM dimmer with a physical potentiometer should maintain the same setting when power is restored.
What type of door sensor are you planning to use — magnetic, IR proximity, or PIR motion?
We also offer a PIR motion sensor switch for LED strips, which might be worth considering if motion-activated lighting suits your project:
Many thanks for the reply. I think I’m most concerned that the initial load will be an issue. I think I’m going to go for a different set up with a different sensor. Thanks for the advice.
Just to clarify, if your 24V power supply stays on, the door sensor would only be switching the downstream dimmer and LED load, not the power supply’s AC-side startup current.
The 30A sensor I shared has plenty of rated current capacity for an 80W LED load (around 3.3A at 24V).
One thing I’d be interested to know — do you want the lights to turn on specifically when the cabinet door opens, or when someone approaches? Our PIR sensor is motion-activated, so the best choice really depends on how you’d like the lighting to work.
