I’m looking at the 16 Inch Under Cabinet Light and had a quick question about the memory function.
When the light is turned off or powered on again, does it remember the last brightness and color temperature settings?
Thanks!
Yes, the 16 Inch Under Cabinet Light is designed to remember the last brightness level and color temperature used.
When the light is turned on again, it will return to the previous settings.
How do I adjust brightness?
You can adjust the brightness of the 16 Inch Under Cabinet Light in two simple ways:
Hand wave sensor: Hold your hand within 10 cm (4 inches) of the sensor to smoothly adjust brightness from 10% to 100%.
Side button: Use the button to switch between 3000K / 4000K / 6000K color temperature modes.
The light also features a memory function, returning to your last brightness setting when turned on.
