Has anyone else used a 660-670nm LED strip like this? How has it performed for you?
Thank you for sharing your experience.
The 660–670nm range falls within the deep red spectrum and is commonly used for plant supplemental lighting, horticultural lighting, and other applications requiring a specific red wavelength. Compared with standard decorative red LEDs, this range is more concentrated within the deep red spectrum, producing a distinct and saturated deep red output.
This LED strip operates on DC 12V constant voltage and is available in different LED densities and protection options, allowing the appropriate version to be selected based on the required light output and installation environment. The 12V power supply should be sized according to the total strip length and power consumption, with appropriate power headroom for stable operation.
For plant lighting or supplemental lighting, wavelength is only one part of the overall setup. LED density, installation distance, operating time, and actual light intensity should also be considered, as these factors can affect the final lighting performance.
