Does this recessed light need a separate bulb?
https://www.ledlightsworld.com/products/eco-1-series-frosted-led-downlight-white-housing-triac-dimmable-3w-5w-7w-9w-4-pack-10-pack-2700k-6000k-100-130v-200-240vDoes this LED recessed light need a special bulb, or can I replace the bulb later if it burns out?
No, this recessed light does not require a separate bulb.
It is a complete integrated LED fixture with built-in LED components. The LEDs are already installed inside the light and are not designed to be replaced like traditional bulbs.
Each light includes its own LED driver, which connects directly to your home’s AC power supply.
This type of recessed lighting is designed to replace traditional recessed fixtures that used separate halogen or LED bulbs, providing a cleaner installation with a built-in light source.
