I’m looking at the OD-PM outdoor LED modules for an outdoor display project.
One thing I’m concerned about is glare. Has anyone used these modules before? How does the screen look when viewed up close or from different angles?
I’m trying to find a display solution that is bright enough outdoors but still comfortable to look at.
The OD-PM Series outdoor LED modules are designed for outdoor display applications, including digital signage and commercial display projects. They feature outdoor protection design with IP65 front protection and IP54 rear protection for reliable performance in outdoor environments.
Regarding glare and viewing comfort, the overall display experience depends on several factors, including module configuration, brightness settings, viewing distance, viewing angle, and the display structure.
For outdoor display projects where visual comfort is important, we recommend selecting the appropriate brightness level and display configuration based on your installation environment.
If you can share more details about your project, such as viewing distance and display size, our team will be happy to help recommend a suitable solution.
