When planning an LED display project, power supplies are often decided last — but in my experience, they’re usually the first thing to cause trouble.
From real projects I’ve worked on, most of the confusion comes down to three things:
Form factor (size):
Some cabinets have plenty of room, but slim or wall-embedded displays leave very little space. In those cases, standard power supplies just don’t fit. -
Wattage margin:
Many displays technically work at full load, but running a power supply at 100% for long periods often leads to heat issues or early failure.
I’ve seen people aim for 20–30% headroom, but opinions seem to vary. -
Operating environment:
Indoor setups are usually forgiving, but outdoor or semi-outdoor installations introduce moisture, dust, heat, and surge risks, which really change the requirements.
So I’m curious — when choosing a power supply for an LED display, what do you prioritize first?
Size compatibility, wattage margin, or environmental protection?
