I’m thinking about installing these rechargeable motion sensor puck lights in my pantry. Has anyone used them there? I’m mainly looking for something that turns on automatically when I open the door.
https://www.ledlightsworld.com/products/rechargeable-led-puck-closet-light-4-6-8-pack-motion-sensor-tap-switch-dimmable-warm-daylight-white-black-white-finish-easy-mounting-for-closets-cabinets
Yes, these rechargeable motion sensor lights are well suited for pantry use.
Some of the features that make them a good choice include:
Motion sensor activation, so the light turns on automatically when you open the pantry door or reach inside.
Detection range of up to 10 ft (about 3 m) with a 120° sensing angle.
Rechargeable battery, with up to around 30 days of use in motion sensor mode, depending on usage.
Adjustable brightness to suit different lighting needs.
Magnetic and adhesive mounting options, so installation is quick and doesn’t require wiring.
I use the same lights in both my pantry and kitchen cabinets. The rechargeable design is much easier than replacing batteries all the time.
I installed a couple of these in my pantry and they’ve been really convenient. The motion sensor responds quickly, especially when my hands are full carrying groceries.
Many customers use these lights in pantries, closets, cabinets, and other storage areas where automatic lighting is helpful.
Since they’re rechargeable and don’t require wiring, they’re also a good option for places where installing permanent lighting would be difficult.
