I’ve been searching for 12volt led strip lights . I did an AI search and your company came up.
I’m a farmer growing veggie starts for markets on the Big Island Hawai’i.
The weather has been a challenge lately and I wanna start compensating with lights.
I’m looking for12 volt full spectrum led strip lights for outdoor applications.
Do you have an affordable product you can recommend?
Thanks for sharing your growing setup!
For supplemental lighting, you may want to consider our 12V red/blue LED grow light strip:
This strip combines 660nm red and 460nm blue LEDs, wavelengths commonly used in plant growth lighting.
It’s worth noting that this is a red/blue grow light strip, rather than a full-spectrum white grow light.
Since you’re planning to use it outdoors in Hawaii, we would also recommend confirming the installation conditions and waterproof requirements before selecting the final version.
I’ve been looking into something similar for starting seedlings. My main concern is whether red/blue LED strips provide enough light, especially during cloudy weather.
Would the distance between the strips and the plants make a big difference?
Yes, distance and coverage matter quite a bit. Seedlings need enough usable light across the growing area, not just the right colors.
I’d also pay attention to moisture protection if the lights are going into an outdoor growing area.
Those are both important considerations.
Red and blue wavelengths can support plant growth, but the actual supplemental lighting performance also depends on light intensity, mounting distance, coverage area, and daily lighting duration.
For vegetable seedlings, we’d recommend confirming the growing area dimensions, the types of vegetables being grown, and whether the lights will be exposed to rain or moisture.
That will help determine whether this 12V strip is suitable or whether a different grow lighting solution would be better.
