Anyone using FL-DMX flood lights in Finland snow?
hi all, i’m looking at the fl-dmx rgb flood light, 100w or 150w version. I want to use them outside in finland, under snow. temperatures could go from +5 to -35, so ip66 is important. Does anyone know if they can handle that, and if they come from germany warehouse for faster shipping? Also, can they do wave movement and color changing, or are they just on/off lights?
If it’s not in the Germany warehouse and needs production in China, you should factor in lead time plus international shipping. For a project in Finland, that could add a few weeks. If timing is critical, maybe check for EU stock alternatives.
IP66 is good for snow and water protection, but I would double-check the operating temperature range in the datasheet. Many outdoor flood lights are rated around -20°C. -35°C is quite extreme. The driver is usually the weak point in very low temperatures.
Thank you for reaching out.
Regarding the FL-DMX Series RGB LED Flood Light (100W/150W):
This DMX flood light requires a DMX controller to achieve color-changing, wave movement, or other dynamic effects.
The lighting effects depend entirely on the DMX controller, not on the light itself.
This product is not in stock in our Germany warehouse. It needs to be produced and shipped from China.
It is IP66 waterproof, suitable for outdoor environments including snow.
